7 members (Jay R, Oswald, 55shaker, Joe H, Jon G, Phak1, dt235sd),
86
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 36 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 36 | I have a 1972 C50 350/4speed with factory power steering, this PS system has a PS pump that circulates pressure from the pump to the steering sector(Box) and a hydraulic ram that attaches to the tie rod on one end and the beam axle on the other. Does anyone have CURRENT part numbers for a rebuild kit for the ram and hoses? I have had many suggestions but all were obsolete or wrong for my application. HELP! | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Rock Auto has some seals/parts listed under "Medium Duty Trucks". Also might check with Lares in Minnesota. You can also measure your old parts and go to a site that lists seals by size.
Evan
