6 members (Peggy M, Bucker, Hotrod Lincoln, klhansen, Hush, Tronman), 76 guests, and 1 robot.
Topics128,206
Posts1,057,435
Members48,471
#1452703 05/25/2022 11:03 AM
As long as I have everything apart for a clutch replacement, I'm replacing the rear main engine seal and the transmission seals, etc.
What is the preferred oil for use in the 3 speed manual transmission?
1950 Chevrolet 3100 (Ol' Roy)
If memory serves me the traditional 80/90 is what is used. I just rebuilt mine and am going to put some fancy AMSOIL 80/140 or something to that effect in it.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Curmudgeon
Curmudgeon
H Online: Content
Really bad choice- - - - -the super slippery synthetic lube will prevent the synchronizer rings from gripping the gears, and you'll end up with a lot of gear grinding, particularly on a downshift. Those heavy gears have enough inertia that synthetics don't work well in them. The straight 90 weight mineral oil (not hypoid) that's specified for Ford N-series tractors is exactly what stovebolt 3 and 4 speeed transmisisons need. Our local source in the southeast USA is Tractor Supply Company, but I'm not sure if that business operates in other parts of the country.
Thanks a lot for all the replies. I know the manual specs 90 but thought with 70 years of exponential improvement in oil technology something else might be more appropriate.
We do have Tractor Supply here and my dad has a '52 8N.
This is what I use in my SM420
Craig
Thanks guys.
What's an SM420?
Sorry about that Otto. Yes, it's my 4 speed gearbox (transmission)
Craig
AD Addict & Tinkerer
Here is what Jerry is talking about and what I use in my ‘52 3100 three speed.
[LINK]
Phil
Project Journals
Stovebolt Gallery Forum
Thanks a lot.
7
7 Offline
I used Valvoline MTF, synchromesh gear oil in my SM420, works good.
6 heaven
6 heaven
The GL1 oil supposedly does not have sulphur in it. In the Ford tractor there are brass components that can be affected by the sulphur content. I think the other oils do have sulphur which is a good lubricant under pressure, like gear to gear contact points. this is what I have been told over the years.
I believe anything up to and including GL-4 doesn’t have sulphur added. At least that’s what my research has revealed. GL-4 is more heavy duty than lower numbers and isn’t too hard to find.
What I used was from a red&white Amoco 5 gal bucket that simply said "90 wt gear oil" that had been in the shop since the 80's. Looked as new as this morning. May be why it still slips out of high gear... I'll switch.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
R Online: Content
I also use the Traveller oil for Ford tractors also and am pleased with the service. I have also used the Sta-Lube brand GL-4, but it’s a bit pricey.
I invest my money in precious metals, mostly rust!
