3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1452560 05/23/2022 11:04 PM
On a 1946 Chevrolet 216, what is the HEX BOLT SIZE/LENGTH of the SIX BOLTS that bolt both the exhaust manifold and intake manifold into the HEAD. Both SAE and METRIC information is appreciated. Planning on using Grade 8 or higher.
I already have the info on the two end studs.
Good luck with the Grade 8 bolts. You'll strip the threads in the cylinder head before you get enough torque on them to keep them from loosening up and falling out. GM used Grade 5 in those locations. As soon as it gets daylight in the morning I'll be glad to measure some bolt length for you on several of the engines I've got stockpiled.
Curmudgeon
Curmudgeon
I have bolts on a 1950 216 that I can remove and measure.
All and any measurements are appreciated.
Fairly certain they are 3/8 bolts (9/16 head) and coarse pitch. But I couldn’t speak to the length or exact pitch.
1951 3100
JW51 #1452601 05/24/2022 1:19 PM
Thanks. I am also sure of the 3/8”-16 bolt. Really looking for the length info.
Crusing in the Passing Lane
Studs and brass nuts make life easier down the road.
Ed
Curmudgeon
Curmudgeon
In order of the yellow circles (left-to-right):
3/8" NC 16 Grade 5
2-3/4" bottom of cap to end of bolt (1949 - newer)
1-11/16" unthreaded shoulder
I don't have a 1948 and earlier engine so hopefully someone else can provide the length.
1-3/8" bottom of cap to end of bolt
1/4" unthreaded shoulder
Curmudgeon
Curmudgeon
Might as well include the "Cons" along with the "Pros'.
Studs instead of bolts, in the head, stick out and can be broken by accident.
A real pain if broken flush.
I don't know if a machine shop would have to remove the studs for head resurfacing.
However, studs would be easier for manifold installation.
Choose your poison I guess.
Darling Now you know the manifolds have to grow a little when heated so not a real high torque setting,also have to shrink when cooling. It's why the pin holes are a little big.
Results, Jerry?
Curmudgeon
Curmudgeon
Hotrod Lincoln or Buoymaker?
I had a set from a 216 and a set from a 235 they are the same.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Curmudgeon
Curmudgeon
1948 and earlier are not the same.
The 216 was from a 51 and the 235 was a newer one so 56 to 62 possibly . They are also Canadian models.
"The Journey"
Follow in the DITY
Curmudgeon
Curmudgeon
Okay I finally found a picture.
My GUESS is that they (1940 to 1948 216), except the end studs, are the same size.
Thanks to ALL, for the input.
Randy
