3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#1452438 05/22/2022 8:25 PM
Found a '40 flat bed. VIN plate still attached with its clutch head screws, on firewall is totally blank (all the paint worn off) but the stamped in number is 5WA123854. Can someone point me to an accurate VIN decode site, please.
TIA,
Wayne
mickey #1452439 05/22/2022 8:35 PM
http://chevy.oldcarmanualproject.com/models/index.htm
5 Kansas City, Missouri plant I believe
WA 133 Utility- 1-1/2 Ton Truck- Single or Dual Wheels
123854 your series number
mickey #1452440 05/22/2022 8:40 PM
mickey #1452447 05/22/2022 8:56 PM
Here's the breakdown for your serial number 5WA12-3854...
5 = Kansas City, MO Assembly Plant
WA = 1940 1-1/2 ton 133" wheelbase
12 = Month (December 1943)
3854 = unit number starting with 1001. So, you have the 2,854th WA out of plant 5.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
mickey #1452455 05/22/2022 10:08 PM
Ex Hall Monitor
Ex Hall Monitor
That's your serial number. Whether it's your "VIN" depends on whether the serial number or the engine number was used on the title as the VIN. Many states used the engine number through 1955.
