| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | I’m looking at installing nos flat tops in place of the dome top pistons currently in my 40 216 and then following that with a 53 216 head suitable for the flat top piston. Are the rings interchangeable between the 2 types of piston?
Hoping I have researched enough to know a later head can be used on an early 216 block if pistons are also changed, but just to be sure are there any issues that could arise or is there anything I should be looking out for?
Many thanks, Dave | | | | | Joined: Feb 2004 Posts: 29,765 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,765 | Just be sure the ring grooves on the pistons you install match the thickness of the rings. A dial caliper is your friend here. Parts don't care where they fit, as long as the specifications are correct. I routinely mix and match parts from different manufacturers, such as using Ford 223 cubic inch pistons in a Chevy 235 to accommodate a change I make in the crankshaft stroke with a different wrist pin height on the piston. Be sure the sheet metal pushrod cover on the side of the engine is the same shape- - -some 216's used a short cover, while others had one that went all the way to the top of the cylinder head. As long as you order pistons and rings for the same year engine you should be good to go. Why do you want to swap? Maybe a bad cylinder head? Jerry
| | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | Hi Jerry, Yes the original cylinder head has faults - burnt valves + seats and wear to the manifold mating surface. Machining is obviously an option but I have this good later one which I think will be the more cost effective option. Push rod cover is the same. Unfortunately the nos flat top pistons come without rings but I have a set from dome tops hence my question. Many thanks for the advice 👠| | |
