| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | I will be going to my favorite Junkyard in a few days and need some GMC help. I know chevy's quite well but not GMC's. At this yard they have 4 big old GMC's with engines in them. Is there any easy way to determine if any are a 270 or 302 ?
55 Cabover
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The engine size is the first 3 digits of the engine number. It's found on the machined boss just aft of the distributor. | | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | Wow, does'nt get any easier than that. Thanks .
55 Cabover
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | What Cletis said. They're both nice engines. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | It may be easier/quicker to identify the engine by the head casting number and then get greasy to view the distributor "boss". I'm sure you know the 302 is the #1 choice but if you have are to choose a 270, try to get one with the famous "H" head; casting number is 2193417. The 302 head casting number is 2193983.
Mike Barnes 1950 GMC 1-ton pickup
