Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (qside), 28 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1452279 05/21/2022 3:42 AM
1950 Chevy 3100 216 3 Speed.
What is the correct position for the ignition switch in the off position. The cylinder is original. A picture would also be worth a 1000 words. I’m not convinced it is correct in the attached picture.
Darren
Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
Curmudgeon
Curmudgeon
CCW = off, like your picture.
My experience is that reproduction Asian switches are junk (sloppy inside).
My truck wouldn't start sometimes with new switch.
I swapped back to my original and used the new key lock cylinder.
Less that 1000 words.
For the original 3-position switch on my '48, straight up = ON. To the left = OFF with key. To the right = OFF w/o key (there's a little lever for this). I suspect that the latter was used in the old days on the ranch or farm when one of several folks might use the truck and keys were a pain in the neck.
Moderator, Electrical Bay
There was a switch made in Taiwan which is an exact (except that the one from Taiwan is rated for 30 Amps) copy of the old general switch sold by NAPA, Western Auto and many others in the 1960s. It has been copied by some folks in China and I hear that one is not so good (sold under Dorman and other brands). The one I got from Taiwan came to me via Amazon in 2018 and was made by Uriah. Now they still have that Uriah switch but it is made in China. Keep looking. If you find the switch from Taiwan, it is top notch.
~ Jon
Here is one switch made in Taiwan for Pollack (high quality): https://tinyurl.com/vfeh8aj3
~ Jon
Darren,
Just an observation. Looks like your lock cylinder/switch might be 180 off (upside down?) compared to bouymaker's pic and what i recall mine looks like.
I think tooth section of key slot should be down and agree with bouymaker's "CCW" info. Dash and interior is looking good.
~ Dan
1951 Chevy 3 window 3100
Thanks. I flippied the assemble 180 deg and that looks correct. Any idea on the choke and throttle orientation? Throttle on top choke on the bottom?
Darren
My choke is on top. Don't know if that's original (but it might depend on your carb?).
My choke was also on top ('52 GMC)
Darren,
From info available in on-line manuals (same in 1948 and 1951 owners in this case) available from "chevy.oldcarmanualproject.com", the original manuals indicate the Choke control is located upper dash and Throttle control is located directly above ignition switch (lower dash). See picture in link below (picture from "bouymaker" matches).
http://chevy.oldcarmanualproject.com/chevyowner/48tom07.htm
Many thanks for the gathered and posted resources from all those that have come before us as well as those currently sharing their knowledge and expertise!
~ Dan
I always thought my switch had slipped in place or been installed wrong by a previous owner.
I assumed it should be like any other ignition switch with straight up being "off" and one click clockwise would be the "on" position.
And my Choke button is on top and Throttle is on bottom.
1950 Chevrolet 3100 (Ol' Roy)
Quick pic of my dash showing the iggy switch, choke and throttle.
Craig
Yes, if you drop your truck off at a shop, remind the guys straight up is ON. The guys at the glass shop ran my battery down while the key was in the right (OFF) position.
Wally, you mean while the key was in the right (ON) position.
Thanks for the great advice. It take a community…
Darren
Chevy Darrin Choke goes on top,learned to drill those stems epoxy in a longer wire a lot of them wire is too short.
