2 members (Patina 54, Chris's 46 / 515), 78 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#1451738 05/15/2022 7:18 PM
A friend emailed me asking asking a question about the rear axle single action shocks. Here is his question:
“I am in the process of reinstalling the rear single action lever shocks on my 1946 GMC. The lower bracket, that is part of the lower spring bracket, tilts upwards about 10 degree or so. It is the same on both the left and right sides. It seems to me that the bracket needs to be parallel to the ground otherwise the linkage arm can't be attached. Before I go and flatten the bracket I'd like confirmation that I'm right. Could you confirm my belief and/or send me a picture of your set up?”
Any help here would be appreciated.
Tom
1946 GMC Project
"Back-in-the-day Restore"
The end of a lever action shock moves in an arc, not straight up and down like a more modern tubular shock. I think that upward tilt is related to the resultant arc. My '37 has the same upward bend in the brackets and I think it needs to be there. I am relying upon memory so I would defer to someone with more knowledge on the subject but don't flatten the bracket just yet.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Tom,
Maybe these [photos will help. My 1946 1/2 T
Harold
Harold
Thanks to both! Much appreciated. Tom
1946 GMC Project
