2 members (KEVINSKI, JW51),
79
Mod | | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'd like to do something to warm up the shop floor. The whole floor would be too ambitious, but maybe something in front of the workbench. When I'm moving around it doesn't seem to be a problem. But standing at the workbench for a while is a different story. Just curious of how others may handle this. Oh, and not interested with a small forced air heater.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2007 Posts: 3,372 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,372 | Have you thought about radiant heating. We added some to our maintenance shops above the work benches and tool boxes, they heat the area very well.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: May 2015 Posts: 11,001 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,001 | It would be expensive on a complete floor that's already in place, but in-floor hydronic heating is the cat's meow. I've got a few buddies with shops with heated floors and it's a luxurious thing when you're working under a truck. Gas fired radiant heaters like Craig suggested would work as well. Or Electric radiant. For a much less expensive option, how about a thick rubber pad in front of your workbench? That would at least insulate your feet from the cold floor. I don't know if anyone makes a heated pad, but that would be even nicer.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | We have NuHeat pads in our bathrooms under the tile. It works well but it's slow to heat up. You would have to anticipate when you were going to be in the shop and have the timer set to turn the heat on before you start work. https://www.nuheat.com/
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Too late for you, but for others considering building a shop, radiant floor heating can not be beat. I have a 24 X32 foot shop and a small boiler heats the floor and gives me on demand hot water at the tap. Even if a fellow wasn't sure when he was building, have the tubing installed at the time you are pouring the floor. It's not that expensive. If your feet are warm, you will feel warm! A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I didn't mention, but I do have an electric heater for the whole garage. Don't really have a place above for radiant heat and only looking for warm feet anyway  . If I were building, I would do the heating in the concrete, no doubt. That NuHeat looks interesting but then I'd have to mud it in. Maybe someone makes an electric heated mat that could lay on the concrete? Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Denis, if you need to warm your feet how about heated socks. https://www.cabelas.com/shop/en/actionheat-aa-battery-heated-wool-socks Just use rechargeable batteries. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | There are heated floor mats ads on Amazon, but the reviews are mixed.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Putting a heating mat directly on the cold concrete floor doesn't sound very energy efficient. Also, one of the down sides to in-floor radiant is you need to leave it on all winter as it takes a long time to heat the concrete before it heats you. My garage has propane fired Inferred heat hanging from the ceiling that's very energy efficient and takes the chill off in about 15-20 minutes. Mike B  | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Putting a heating mat directly on the cold concrete floor doesn't sound very energy efficient. Also, one of the down sides to in-floor radiant is you need to leave it on all winter as it takes a long time to heat the concrete before it heats you. My garage has propane fired Inferred heat hanging from the ceiling that's very energy efficient and takes the chill off in about 15-20 minutes. Mike B  That's true, but I am out there almost every day. It doesn't need to be cranked way up, and my boiler is rated at 96.1% energy efficient. The bonus is I live in the lower mainland of BC and we do not have what I would call a harsh winter. I am thinking of retro-fitting my house heating from a forced air gas furnace to radiant floor. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Well, I may just use a 4x8 oriented strand board to get some insulation and let it go with that. Thanks for all the comments. Getting warmer anyway
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Go to your local Farm Store and purchase a rubber stall mat. Provides a bit of insulation from the cold and cushions your feet.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hmm, maybe I 'll do just that. Thanks Martin
Dennis
40 Chevy 1/2 ton
