5 members (UtahYork, Bucker, Buckeye998, Stovebolt48, Hotrod Lincoln), 152 guests, and 2 robots.
Topics128,190
Posts1,057,339
Members48,469
#1451147 05/09/2022 6:45 PM
Hi,
I'm having some technical issues with my 270 engine in the machine shop.
I'm curious if parts are interchangeable with a 248 and if so where does it state that the parts are interchangeable?
I have a service book for the 100-400 series trucks and cant find if anything is interchangeable. Am new to engine rebuilding
James
Crusing in the Passing Lane
What are the issues?
Ed
Shop says conecting rods and cylinder head are for a 248 and not a 270 although they came out of a 270
Here are pages that detail engine specifications - I am not a GMC Knowledgeable person, I found these doing a search and thought they might be useful, covers a lot of information regarding engine specs, casting numbers, etc....courtesy oldgmctrucks.com
right click on image, open in a new tab, then magnify..
The GMC Heads page has some good details regarding head casting numbers and the model year.
Hopefully a GMC expert will be along shortly to provide more information...
Ron - - Dusty53
1954 Chevy 3604
That info shows what is different between the designations, I can't see them tooling up for different con rods and heads. Even other parts that may need a change are likely done by machining them to different dimensions.
You have to love those odd fractional dimensions of that era, like the Bore and Strokes.
Gmc 270 and 248 use the same rods. Some of the early gmc rods used a different big end bearing. The main difference is the small end changed in about 53 they went from a .990 to a .1050 small end.
What is the casting number on the rods you have ?
There are only 4 different heads, and certain ones go only with certain pistons. Some have larger ports.
Ed
