2 members (Ponchogl, 1955 1 Series), 376 guests, and 4 robots.
Topics128,163
Posts1,057,044
Members48,463
Hi all, as title.. heater hose is too small. And would kink. I need to go 180* then down on angle from that. Parts stores did have any formed hoses like that.. any help?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Crusing in the Passing Lane
I use Cu pipe bends and straight stretches if necessary.
Ed
How about a gates 22373 or 21660? Depending on the rest of yoyr run, it might need spliced into something else, but they are 1.5" and have good sweeps.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Either soldered copper pipe, or CPVC plastic (the cream colored stuff) will handle cooling system pressure and heat. Then use short pieces of hose on both ends to connect to the radiator, water pump, or whatever else there is in the system.
Thanks guys.. looking at all you posted. Attaching a not so great pic of what I would have in a perfect world if you guys want to add anything...
