4 members (NJC, klhansen, kades51, MRMEROTH11), 89 guests, and 2 robots.
Topics128,066
Posts1,055,875
Members48,428
#1450754 05/05/2022 11:45 PM
I'm sure this has been asked alot on here, but how does this engine decode? It doesn't seem to follow the structure of straight 6 engine numbers. The engine is orange and appears to be a 235. It has the 2 acorn nuts on the valve cover and the side cover is below the spark plugs
I think it’s a 216 from a 1940 (K) 3/4-ton (E) manufactured in Flint (A).
Professional Novice
Here's your engine serial number KEA169397 break down...
KEA = 1952 235 made in the Flint Engine Plant and installed in the 6000 series trucks
169397 = unit number starting with 1001
Note, the capitol letter "eye" is used as number "one".
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1450776 05/06/2022 2:21 AM
Mike B smile
Those metal stamp kits only had nine stamps if numeric only kit. Turn the 6 over to get a 9.
The alphanumeric stamp kits had no zero (use the alpha O), no one (use the alpha I) or nine (turn the six over).
Mike B, I think you are correct. It actually makes more sense.
Professional Novice
Thanks for the replies. It's in my 1946 2 ton & I had a feeling it wasn't the original engine.
