1 members (Bill Hanlon), 167 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,471
#1450718 05/05/2022 6:31 PM
I'd like to do something to warm up the shop floor. The whole floor would be too ambitious, but maybe something in front of the workbench. When I'm moving around it doesn't seem to be a problem. But standing at the workbench for a while is a different story. Just curious of how others may handle this. Oh, and not interested with a small forced air heater.
Dennis
40 Chevy 1/2 ton
DennisM #1450722 05/05/2022 6:41 PM
Crusty Old Sarge
Crusty Old Sarge
Have you thought about radiant heating. We added some to our maintenance shops above the work benches and tool boxes, they heat the area very well.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
DennisM #1450731 05/05/2022 7:44 PM
It would be expensive on a complete floor that's already in place, but in-floor hydronic heating is the cat's meow. I've got a few buddies with shops with heated floors and it's a luxurious thing when you're working under a truck.
Gas fired radiant heaters like Craig suggested would work as well. Or Electric radiant.
For a much less expensive option, how about a thick rubber pad in front of your workbench? That would at least insulate your feet from the cold floor. I don't know if anyone makes a heated pad, but that would be even nicer.
DennisM #1450736 05/05/2022 9:05 PM
Insomniac
Insomniac
We have NuHeat pads in our bathrooms under the tile. It works well but it's slow to heat up. You would have to anticipate when you were going to be in the shop and have the timer set to turn the heat on before you start work.
https://www.nuheat.com/
Gord 🇨🇦
1954 1/2 ton 235 4 speed
DennisM #1450739 05/05/2022 9:49 PM
Big Bolt Forum Co-moderator
Too late for you, but for others considering building a shop, radiant floor heating can not be beat. I have a 24 X32 foot shop and a small boiler heats the floor and gives me on demand hot water at the tap. Even if a fellow wasn't sure when he was building, have the tubing installed at the time you are pouring the floor. It's not that expensive. If your feet are warm, you will feel warm!
1948 Chevy 2-Ton
DennisM #1450746 05/05/2022 10:44 PM
I didn't mention, but I do have an electric heater for the whole garage. Don't really have a place above for radiant heat and only looking for warm feet anyway smile. If I were building, I would do the heating in the concrete, no doubt. That NuHeat looks interesting but then I'd have to mud it in. Maybe someone makes an electric heated mat that could lay on the concrete?
Dennis
40 Chevy 1/2 ton
DennisM #1450747 05/05/2022 11:06 PM
Denis, if you need to warm your feet how about heated socks. https://www.cabelas.com/shop/en/actionheat-aa-battery-heated-wool-socks
Just use rechargeable batteries.
1948 Chevy 2-Ton
DennisM #1450748 05/05/2022 11:13 PM
Insomniac
Insomniac
There are heated floor mats ads on Amazon, but the reviews are mixed.
Gord 🇨🇦
DennisM #1450779 05/06/2022 2:30 AM
Putting a heating mat directly on the cold concrete floor doesn't sound very energy efficient.
Also, one of the down sides to in-floor radiant is you need to leave it on all winter as it takes a long time to heat the concrete before it heats you. My garage has propane fired Inferred heat hanging from the ceiling that's very energy efficient and takes the chill off in about 15-20 minutes.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1450847 05/06/2022 4:26 PM
Mike B smile
That's true, but I am out there almost every day. It doesn't need to be cranked way up, and my boiler is rated at 96.1% energy efficient. The bonus is I live in the lower mainland of BC and we do not have what I would call a harsh winter. I am thinking of retro-fitting my house heating from a forced air gas furnace to radiant floor.
1948 Chevy 2-Ton
DennisM #1451242 05/10/2022 5:34 PM
Well, I may just use a 4x8 oriented strand board to get some insulation and let it go with that. Thanks for all the comments. Getting warmer anyway
Dennis
40 Chevy 1/2 ton
DennisM #1451245 05/10/2022 5:39 PM
Go to your local Farm Store and purchase a rubber stall mat. Provides a bit of insulation from the cold and cushions your feet.
DennisM #1451249 05/10/2022 6:09 PM
Hmm, maybe I 'll do just that. Thanks Martin
Dennis
40 Chevy 1/2 ton
Moderated by  J Lucas
