| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | While the engine is out of the truck and on the stand I would like to set the timing. What tool should I insert into the harmonic balancer pulley so I can rotate it to TDC? I know there was a rod that would have been used to start it back in the day, but it was missing when I bought the truck. I’ve never known anyone who actually had one. The fan belt is currently not installed. I know I can insert a screwdriver into the flywheel teeth and rotate it that way, but that takes a very long time! Thanks
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | If you have the spiral crank lugs on the balancer, it's easy to fabricate a short crank handle from a piece of steel round stock and a dowel pin. Just use a torch to bend the rod into shape. Most newer stovebolt balancers have a squared-off hole in the front that a 3/4" square drive ratchet will fit into and turn the engine. I use a 1/2" drive to 3/4" drive adapter on a long handled ratchet to turn engines with that type of balancer. It's also possible to weld a junk 1/2" drive socket picked up from a pawn shop to a short piece of flat bar, and bolt it to the balancer with two short 3/8-16 bolts, using the harmonic balancer puller holes. "There's lots of ways to skin a cat!" Jerry
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks Jerry. I’ll look closer at the balancer when I get home. I thought they all had the spiral crank lugs. It’s a 1955 1st series 235 motor.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the damper has holes to use a puller or bolt pulleys onto, put 2 long bolts in the holes & use a long bar or pipe to turn it .
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Spotbilt xo You could buy a flywheel wrench,use a pipe wrench...carefully,make a tool asHotrod says,you can turn it with a 9/16 end wrench on the pressure plate bolts if it's not to stiff, sometimes use a rag on the ring gear by hand. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Chuck, I believe the last engines to have the crank lugs were the early full pressure 235's - - -1954 and 55 1st. series. The large diameter dampers used on the later 235's and 261's are the ones I've seen with the squared-off center hole that a 3/4" drive will fit. Jerry
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I have been using a big version of a oil filter wrench that has the rubber strap. The strap goes around the crank pully and I turn as needed. | | |
