4 members (1955 1 Series, Ole49GMC, Otto Skorzeny, DaveV), 95 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#1424555 09/19/2021 11:25 AM
Has anyone installed power steering on '52 6400 if so how
Crusing in the Passing Lane
Are you wishing to use existing location for pitman arm shaft through the frame or another location. Saginaw(Delphi) box can be mounted up front, outside frame with existing steer arms from spindle- Some fabrication required?
Ed
Thanks Ed for the info. I'm in process of and ls swap. Power steering will be a great help
There is a unit that uses the 3 original mounting bolts, shaft goes through original hole, new pitman arm attach to original lineage. Have not done myself, others have. CPP sells them.
Ed
Ed
Ed, those set-ups are for the 1/2 ton trucks only...he's building a 2 ton, there are no kits for the big trucks.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
i've thought about this topic a lot, and i just so happen to have a few modern big trucks right beside my own 6400, and it appears that it would not be too difficult to put a power steering system from a newer big rig on there. of course, it would hardly be feasible to find a pump that would work with big riog steering and an LS, but it looks like the box itself would fit with minor modification. it would be far from bolt on though, you'd need a lot of custom bracketry and things. i've got a '96 f800 with a 5.9 12v cummins, and it appears to have a very similar arrangement, and the engine itself would be a great candidate for my 'bolt. something like that may be good to look for.
