2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#1450400 05/03/2022 4:16 PM
What kind of grease do you put on your distributor grease cup? Would John Deere Corn Head grease be ok to use? Mine has what looks like chassis grease in it. I guess that's what the machine shop that rebuilt my 235 uses.
AD3100 #1450401 05/03/2022 4:28 PM
Original spec was for petroleum jelly.
AD3100 #1450408 05/03/2022 4:59 PM
Pretty sure I used chassis grease.
1951 3100
AD3100 #1450435 05/03/2022 8:04 PM
Ex Hall Monitor
Ex Hall Monitor
Never heard of petroleum jelly. I use chassis grease. I've found bearing grease isn't viscus enough and squeezes out around the threads of the cup.
Tiny #1450449 05/03/2022 9:41 PM
Tiny Petroleum Jelly is vaseline.
1961 Chevy C40 Flatbed 261
AD3100 #1450455 05/03/2022 10:01 PM
Leo Offline
Moderator
Moderator
I used chassis grease in my distributer cup and petroleum jelly on my feet.
AD3100 #1450466 05/03/2022 10:58 PM
AD3100 Just gun grease,chassis grease,lubriplate use cornhead in your steering so the seal doesn't leak so bad.
AD3100 #1450474 05/03/2022 11:59 PM
Insomniac
Insomniac
The truck manual I have says "chassis lubricant"*
* Chevrolet Truck Shop Manual 1954 p. 12-32
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Ex Hall Monitor
Ex Hall Monitor
I know that. I meant I never heard of it being used as dizzy lube.
Tiny #1450485 05/04/2022 12:35 AM
I went with chassis grease after removing the spring, cleaning and inspecting. There was not a wear disc inside, so I turned a piece of round stock plastic on the lathe to make it a loose fit inside the hole. I made the disc with a reduced end tab that's a press fit into the spring. That way it will come out with the spring if I ever need to remove it.
I used corn head grease in my steering box and have a little left on the shelf so thought I ask about it.
Thanks for the replies!!
Tiny #1450496 05/04/2022 1:50 AM
Oh haha sorry Tiny. Wondered if you were living under a rock grin......
AD3100 #1453322 05/30/2022 12:32 PM
AD3100 That cornhead grease will go liquid in Burelson in summer,helps steering a lot.
