2 members (Gray_Ghost, 1 invisible),
75
Mod | | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Friend has a 54 Chevy panel with a 350 in it. Yesterday he was driving and everything was fine, then things turned south. He just made it home, plugs on one side are fouled, any thoughts as what might do this. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Does he have dual exhausts? Crumpled pipe?
Ed
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I don't know I will have to check. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2022 Posts: 2,493 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,493 | Maybe the exhaust manifold heat valve (or whatever it is called) is stuck shut causing all exhaust on one side to be forced under the carb through the intake manifold carb heat path to the other side??
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | Or, intake manifold not sealing on one head and sucking oil/coolant into one bank.
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Update, he has replace parts to no avail, today he ran it and it backfired through the carb, he noticed fire come from the carb base, he may have a vacuum leak. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Firing back up through the carb is pre-detonation of the fuel. All can be caused by excess fuel(running to rich), timing to far advanced and the intake valves aren't completely closed before spark, or an intake valve(s) not seating completely. Either way you have fuel igniting back up into the carb. Fouled plugs are a good indicator of running rich. What's he using for a carb?
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Oct 2014 Posts: 142 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 142 | It could have wiped a camshaft out, but usually things gradually go south when that happens and not all at once like you said. Fire coming out around the base is a sure sign the base gasket is bad and could be the root cause of the original issue. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | homer 52 If gasoline flies back up out of the carburetor it may be stopped-up exhaust system,you know like that old schoolbus trick...potatoe up the tailpipe. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | This has not been resolved yet, my friend has more ed parts on order, I will report on results, he has put a lot of money into this problem. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Quit shotgunning parts at the problem and do some diagnosis. Try pulling the intake manifold and look for a vacuum leak at the bottom of the ports on the side that's fouling the plugs. Have the heads been milled? Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am not doing this Jerry, my friend is. I am just trying to get suggestions to help him. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | As the saying goes.... Test, dont guess. Id check the timing chain to see if the chain jumed a tooth. Especially if it happened all at once. Do a compression check also. It will tell ya alot and not cost anything but time.... | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Compression check was all cylinders good and even, I think he said 145. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Good compression, plus fouled plugs on only one side screams "Vacuum Leak"! A milled head can expose the bottom of the intake passageways to the crankcase unless the intake is also milled to align the ports, and it ALWAYS happens on the bottom. Some NASCAR teams did that deliberately. The engine would run lousy and smoke during caution laps, then clear out and suck a little extra air past the restrictor plate at speed. One backfire can push the bottom of the intake gasket out and create a vacuum leak on an otherwise good-running engine if the gasket is just barely sealing before. Jerry
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Good compression, plus fouled plugs on only one side screams "Vacuum Leak"! Jerry Wouldn't a vacuum leak cause a lean condition? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Has he pulled the valve cover on that side. It may be the oil drain holes on the cyl. head may be plugged up letting oil get sucked down the intake valve guides.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Wouldn't a vacuum leak cause a lean condition? Yes. According to the original post, it's barely running, which happened suddenly. Sucking air and oil through a leak between the intake and the head will oil foul plugs quickly, and make the engine run rough. Fuel fouling and sooty plugs from running rich, on only one bank is highly unlikely. Sooty plugs indicate a fuel problem. Black, oily deposits are a different can of worms. We simply don't have enough accurate information to do more than guess about this situation. Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I totally agree, he has shot gunned the process so much we really don't know what is going on. I will report on the final solution if there is one. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Not to mention, the lack of engine specifics dont help in any way of diagnosing this mysterious creature.
By the way what carb and intake are on this thing? Pics?
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I know he changed carbs during this exercise plus lots more, not sure about the intake manifold. I have told you all I know. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Well it is running great right now. Long story shortened. He was convinced it was first spark, new distributor installed, then new wires, then he thought carburation and changed the carb. After sitting and talking with him ai guess I finally got him thinking about the intake gasket. When I stopped by his place yesterday he was putting the manifold in and installing the carb. He wanted to let the sealant setup in the valleys so we did not attempt a start. He said I think I am doing a lot of work for nothing! Today he called me and said it was running good. Called me a few minutes ago and thanked me for pushing me on the intake gasket. NOW, I want to thank all of you that contributed to this troubleshooting exercise! Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | There's an old Winston Churchill quote- - - - - "The Americans can always be counted on to do the right thing, after they have exhausted all other possibilities!" The same can often be said of hotrodders! Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Jerry, I have dreamed up some ideas on how to check for an internal vacuum leak, how should you check without just replacing the gasket? 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | If you can block off any kind of crankcase vent system and figure out a way to adapt a vacuum gauge to a valve cover or an oil filler cap you'd probably be able to see at least some vacuum on the crankcase. One of the "smoke generators" used to find leaks in closed loop ventilating systems on newer emission controlled cars might be useful if a test procedure could be developed. If your buddy is dealing with a milled head and a poorly-fitting intake, installing new gaskets might only be a temporary fix until the vacuum distorts the new side gasket. If it was just a gasket installation mistake previously, he might have made a permanent fix this time. Jerry
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Jerry, as long as the engine will run could you use the unlit propane torch trick?
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I'd be reluctant to put Propane into a crankcase- - - - -launching a set of valve covers into low earth orbit would be a distinct possibility. I've seen a severely flooded MOPAR 361 engine develop enough fumes in the crankcase to bulge the valve covers and oil pan when a spark plug finally dried out enough to fire. There was a hole burned in one piston, and the crankcase vapors exploded. I felt the breeze as the oil filler cap went past my left ear. We never found the filler cap, and my ears stopped ringing after about 15 minutes! Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | One of my thoughts was to use my differential pressure tester I use to do compression testing on aircraft. The thought was to rotate the engine until an intake valve opens then block off the carb, add pressure to the cylinder and check the crankcase for pressure. The only thing is how much pressure would you dare put on it. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I'd try 1-2 PSI at most. The problem will be getting all the potential leak points in the crankcase plugged- - - -oil filler, PCV valve plumbing, etc. Putting smoke into the cylinder and watching an oil fill point might be more effective. Find a buddy who likes to vape, and let him huff some smoke into the spark plug hole! LOL! You could also loosen up the rocker arms to close all the intake valves and apply a little bit of pressure to the carburetor inlet, maybe with the blower side of a shop vacuum cleaner, or maybe a hair dryer with the heat turned off, and check for leakage at the oil fill cap. Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Good thoughts Jerry. I am just wondering if this is a permanent solution or it will be coming around again. Time will tell. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Look at the thickness of the head casting where it meets the block below the spark plugs. An unmilled head will be approximately 1/4" thick there. If it's been milled enough to disrupt the head/intake fit and compromise the bottom of the intake ports, the thickness will be closer to 1/8". When I would angle mill heads 0.100" to turn a 76 CC combustiom chamber head into 60CC's, we also had to custom fit the intake to the heads to make the intake ports line up. Ray Charles could have caught my milled heads by simply running his fingers along the sides, but the tech inspectors were too dumb to do anything other than check casting numbers. If a head is milled straight down instead of angled toward the spark plug side, it only takes about 1/16" of head nilling (.0625") to start running into intake runner problems. Once heads are milled very far, the heads and a custom fitted intake need sto stay together as a matched set. Jerry
| | | | | Joined: Oct 2021 Posts: 6,955 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,955 | I had a similar experience with an Ford inline six. Backfiring through the carb, fouled plugs, etc.
I thought the timing was off so I checked chain tension, Compression, etc. It turned out to be a faulty condenser in the dizzy.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | An update here. My friend had continuing issues with this engine, he has now replaced the intake manifold. He told me the old one had evidence that someone did some metal removing and one side is not perfectly flat. He will hopefully drive down to Homer on Sunday for a show. This will test it. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I wish him the best of luck- - - -I'm pretty sure he's going to need it! Jerry
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Today he went Ninilchik to Homer and return and had no issues at all, he thinks he has it whipped . Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
