1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1449819 04/28/2022 10:51 PM
Custom Title
Custom Title
On a '54 235, what size is the steel fuel line that runs from the pump to the carb? I need to order some parts but I'm hundreds of miles away from the truck right now! Thanks in advance!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Curmudgeon
Curmudgeon
