| | | Forums66 Topics128,042 Posts1,055,515 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14496 03/13/2004 11:56 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | does any one know a site on ratios? I am thinking about changing ratios in my G 20 van. Thanks. Mike | | |
#14497 03/14/2004 4:55 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Slomoe, email me and I will send you a very handy ratio calculator, if that is what you are looking for.
You can plug in different ratios and tire sizes to determine MPH or RPM. | | |
#14498 03/14/2004 5:16 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | afu, I tried to send you an e-mail. Don't know if it went through. That calculater would help a lot. Thanks. Mike [email protected] | | |
#14499 03/14/2004 5:31 PM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Do a web search for Randy's Ring and Pinion. They have some easy to use calculators.
40 Chevy 1/2 ton
#14500 03/14/2004 5:35 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | | | |
#14501 03/15/2004 12:43 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Slomoe, check your email, I sent you the calculator. | | |
