5 members (TUTS 59, Rusted Nut, fonz8261, klhansen, moparguy), 131 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#144951 11/19/2005 10:01 PM
Junior Member
Junior Member
Can anyone tell me where I can get shoes or have mine relined for the parking brake on my 61' C60. Everywhere I go or call they tell me that they can't get or don't have a reline kit. I live in North Alabama
1961 c65 flat dump
1973 c50 flat bed
#144952 11/19/2005 10:11 PM
Is this a band brake on trans? Maybe smaller inner shoe too? I have mine re-lined, riveted too at local brake wholesaler/dealer in my area. Seems like $30 last time, but been awhile. Used ones usually have grease all over them, don't hold well. Did you try to adjust first? There are two or three places to do that, check with feeler for clearance. Shows this in manual.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#144953 11/19/2005 10:23 PM
There is a fleetpride truck parts in Albertville. They should be able to help you. They have a web site so you can find a store close to you.
#144954 11/20/2005 10:46 AM
Junior Member
Junior Member
I did call FleetPride they are about 5 miles from me they said they didn't have the kit. I think I still should go there in person and show them what it is I am needing. My Pops works in Birmingham I gave him the shoes he said he would stop by Birmingham Brake And Clutch next week if no luck I'll head to FleetPride. Thanks and I will keep you posted.
1961 c65 flat dump
1973 c50 flat bed
#144955 11/21/2005 12:17 AM
When I use to work in a garage, I had them Reline a brake band for me. They sent it out to get done. You might be able to bring the shoes right in and they should be able to match it up.
#144956 11/21/2005 3:53 AM
Fort Wayne, IN has Brake Materials and Parts Sherman Blvd. 260-426-3331 ask for Scott Bethke. They have the metal bands w/out lineing hanging by a shelf if needed, will re-line yours if you send in. Gotta be someone like that down your way!!
G.L. Grumpy's
Old Iron Ranch
#144957 11/28/2005 11:52 AM
Junior Member
Junior Member
Ok Pops took the shoes to Birmingham Clutch & Brake witch is now "Clutch and Brake Specialist" and they had no problem bead blasted the shoes and relined them they look new goning to paint them and install this week
1961 c65 flat dump
1973 c50 flat bed
