| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 9 Junior Member | | Junior Member Joined: Oct 2005 Posts: 9 | Can anyone tell me where I can get shoes or have mine relined for the parking brake on my 61' C60. Everywhere I go or call they tell me that they can't get or don't have a reline kit. I live in North Alabama
1961 c65 flat dump 1973 c50 flat bed
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Is this a band brake on trans? Maybe smaller inner shoe too? I have mine re-lined, riveted too at local brake wholesaler/dealer in my area. Seems like $30 last time, but been awhile. Used ones usually have grease all over them, don't hold well. Did you try to adjust first? There are two or three places to do that, check with feeler for clearance. Shows this in manual.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | There is a fleetpride truck parts in Albertville. They should be able to help you. They have a web site so you can find a store close to you. | | | | | Joined: Oct 2005 Posts: 9 Junior Member | | Junior Member Joined: Oct 2005 Posts: 9 | I did call FleetPride they are about 5 miles from me they said they didn't have the kit. I think I still should go there in person and show them what it is I am needing. My Pops works in Birmingham I gave him the shoes he said he would stop by Birmingham Brake And Clutch next week if no luck I'll head to FleetPride. Thanks and I will keep you posted.
| | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | When I use to work in a garage, I had them Reline a brake band for me. They sent it out to get done. You might be able to bring the shoes right in and they should be able to match it up. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Fort Wayne, IN has Brake Materials and Parts Sherman Blvd. 260-426-3331 ask for Scott Bethke. They have the metal bands w/out lineing hanging by a shelf if needed, will re-line yours if you send in. Gotta be someone like that down your way!!
| | | | | Joined: Oct 2005 Posts: 9 Junior Member | | Junior Member Joined: Oct 2005 Posts: 9 | Ok Pops took the shoes to Birmingham Clutch & Brake witch is now "Clutch and Brake Specialist" and they had no problem bead blasted the shoes and relined them they look new goning to paint them and install this week
