5 members (tclederman, gswbbc, Uncles51, dwreills, Peggy M), 83 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#1448870 04/20/2022 10:33 PM
Hello All,
Does anyone know if there is a kit to just put seals in for a box that works great but leaks?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
What oil/lube are you using?
Where is it leaking?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thats a good question! I still need to look up what to use for this thing! I will have to look up close and wont be in front of it til Fri.. :/
[edit] I looked up steering 'fluid' after your clue sir and mainly, it should be filled with a type of grease! dang I think someone put power steering fluid in it from the way it looked IIRC!
If it is a stock ‘38 steering box it uses “Cornhead grease” found at your local Farm Store.
Oh I will try this. Yes it is stock. Thanks guys!
You can replace the sector shaft seal with a more modern type (rubber lip seal) for pretty cheap. The original is a felt seal that is pretty much just a strainer. Same as a later model pitman shaft seal SKF 11055.
B Online: Content
I did the felt seal (which leaked like a sieve even with JD Cornhead grease in the box) to lip seal change on my '52 GMC 150. Left the steering box in place. Removed the Pitman arm. Dug out the felt seal with various small pointy tools and tapped in the lip seal. Not a drop in over a year.
38 1.5 ton I think I read somewhere to use 3 drywall screws to pull the old seal out,then put in new seal. Have been using corn head grease works fine.
I also removed the pitman arm and installed a lip seal and filled it with 90 wt. gear lube. And it leaked through the threads on the bottom of the steering box where the large adjustment nut is. These trucks are suppose to leak fluid. That's how you know they have some in them! We need to realize these truck were designed in a different time. The original felt seal would also leak. When components stop leaking that when they need checked!
2 Offline
chris,
i think 90 wt is too thin for the steering box, the original stuff in there would have been like lard on a cold day "self leveling grease"
but i did like you
however before assembling i studied those threads and the bushings and the smaller adjustment bolt thing on the side, and made modifications so that i could fill mine up with 80 wt oil and it doesn't leak anywhere now
the next one i do, i'll just try to find the right stuff to put in it, but i'm probably still gonna seal the thread leaks again to keep dirt out.
-s
I have all ways wondered how our camp commandant has kept those rear hubs and wheels on his 46 2 ton so white? What's the secret?
My truck has a spring loaded oil cup to fill the steering box, so the fluid must be pretty thin! Also, I just looked it up in my 1946 Chevrolet truck owners manual. It says use AII Purpose or Universal gear lubricant. Also the manual call out "ALL Purpose" Gear Lubricant as S.A.E. 90. The manual also states there's no need to ever drain the steering box but gear oil can be added. This tells me the factory may expect the steering box to leak! These old trucks where expected to leak. I don't understand why every body says use the JD corn head grease.
