2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1449139 04/23/2022 5:24 PM
Can anyone help ID this trans? My best guess is early 50's Hydramatic, but I'd like to confirm. Thanks in advance.
RustyGMC #1449144 04/23/2022 7:16 PM
Curmudgeon
Curmudgeon
8617230 is the cast number for a Hydramatic Transmission case.
In the Chevrolet Master Parts List it says:
58-62 All with H.T. (2nd. design) (exc. 1/2 ton) part number 8617232
I have no GMC parts list but this transmission case was probably used on a GMC as well.
Look at the other side. There should be an oval tag with serial numbers.
On the torus cover there should be a rectangular tag with the engine serial number (engine and transmission are matched).
RustyGMC #1449147 04/23/2022 7:49 PM
Curmudgeon
Curmudgeon
Just found part numbers on GMWIKI. Chevy truck and GMC both used this case.
RustyGMC #1449171 04/23/2022 11:57 PM
Originally, there would be a stamped label. It would be either on the opposite side of the case or just above the rear of the pan rail and to the driver's side of center. It'll have the tranny serial number, starting with year and a one or two letter type that will identify what vehicle it left the factory in.
Pages below are from "The Hydra-Matic Transmission 1946-1955 On The Car Adjustment Service Manual. They don't cover later models. Olds and Pontiac used these dual-range Hydra-Matics through 1956, Chevy trucks through at least 1959 and GMC until at least 1962,
RustyGMC #1449211 04/24/2022 1:32 PM
Rusty GMC If you can get that tranny to work you'll find out they are great,really pull in low gear,smooth shifter !!
RustyGMC #1449744 04/28/2022 6:57 AM
Thanks guys, much appreciated. Funny how things can be misidentified, the guy I got it from said it was the original Powerglide out of his '51! Obviously not a Powerglide, but he threw me off on the date. I'm sure the trans was swapped before he bought the truck.
