1 members (1 invisible), 92 guests, and 2 robots.
Topics128,109
Posts1,056,572
Members48,448
I have checked with my local parts houses and no one has blocks.
What should I buy for blocks? Assuming I will want a rigid and flexible? Is this a amazon purchase?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
back yard wrench turner
I bought a set of sanding blocks from Amazon. I also bought 2 rolls of self adhesive sand paper in 2 different grits from them.
The longest block is about 15 inches. Also got a couple contour blocks with the kit.
sanding block kit
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Thanks. That what I was looking at, and the next one cheaper. Wont be here for three weeks unfortunately. Guess I yank the engine and get that running.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I have the same set that Wayne linked. Where are you that Amazon won't deliver for 3 weeks? They even get some stuff to me in Alaska in 3 days. (I think they fly their jet up here though).
NH? Not sure why? maybe a stock issue? April 17th is the expected day.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Hmm. I just looked at the link that Wayne posted and it says it would be to me by Friday if ordered right away today. ohwell
But that's Amazon for you. frown
Well, lets hope they come sooner. If not here by the weekend I am going to begin ripping the engine out.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I don’t understand the shipping I ordered a firewall pad and it started in Arkansas,to Miami and back to Ontario The package went for a 20 hour drive in the opposite direction before heading back.I guess I got my 50 bucks worth of shipping charges .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
That sanding block kit contains the several blocks my professional paint supply house recommended. They work great. Remember to always use the longest possible in any given space.
For curves, I used various diameter heater and radiator hose wrapped with sandpaper.
DonBolt
1955.1 3100
235, 12v, 5-window, 5 speed
All great advice.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Just checked tracing. It is ordered, but no filled yet.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Arrrgggg. Still no blocks!!!!! Now they say another week.
If anyone local to me had them I would have bought them.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I use the Durablocks and soft sanding blocks. They are on Amazon also. Mutli-colored hard foam blocks in different shapes. Stiff yet flexible and they really help getting around and into compound curves and details. They come with samples of self sticking sanding sheets and you can buy more.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
A number of times, I've gone straight to the source of the product that I was looking at on Amazon and got a better price and free shipping to boot. Amazon is convenient, but sometimes it just sucks.
If you can get up to Gorham, I'll lend you my sanding blocks. Round trip you will have what you need in 4 hours plus a cold one.
1946 GMC Project
"Back-in-the-day Restore"
That's the stovebolt spirit! thumbs_up
See edited note. That's a spirit too chug
1946 GMC Project
Moderator, Electrical Bay
J Online: Content
I just get these at Rockler. I have about 5 for different grits and then I can purchase any type paper I need. From each sandpaper sheet you get 4 pieces for the hand sander. I've used this same sander for over 50 years and it has always worked fine. https://www.rockler.com/rubber-sanding-block
~ Jon
Blocking a body, especially Panels and Suburbans, require a longer block. This way you end up with a straighter panel.
Thanks Tom. While I have been waiting for them I ripped the engine out. Went through trans and am priming this evening. Going to get yo removing pass side rocker tomorrow and start working on the cab on same side.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Sounds like you are knee deep into it and steaming ahead. Good!
1946 GMC Project
You can make your own long block that works pretty good. This is what I used for my truck. Just a nice flat hardwood board with saw cuts to give a bit of flexibility. I made several with different saw cut patterns for more or less flexibility. Once the panel is straight with the 80 or 120 grit then you can use the smaller rubber blocks for the fine grit sanding.
Mark
home made sanding block
Thanks 59 Fleet.
I had made my own as well from straight dry dimensional Lumber but was convinced I should buy some.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
I know you wanted some Durablocks, but have you looked at some of these other companies?
Big Kid Blocks
Lucky Blocks
True Blox
I haven't looked at them. I have no brand loyalty. Today is the day of supposed arrival. We will see.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
