1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14480 11/05/2003 7:20 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have noticed that on the Bridgestone tire site, they have a tire for a light truck that is steel belted, is listed as a 16 x 750, and the recommended rim width is 5.5" . I believe the diameter is around 31" or 32". Now this would be a great replacement for wheels and tires on the AD 1 and 3/4 Tons. I would think that a 5.5" rim width would probably come with a 3.00" backset. Does anybody market such a rim? | | |
#14481 11/05/2003 8:05 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | If you are interested in after-market rims, check out Summit. They have almost every conceivable rim diameter, bolt pattern, and backset. | | |
#14482 11/05/2003 8:19 PM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | check with Canadian Wheel. I bought my rims from them and the service was great. http://www.canadianwheel.com | | |
#14483 11/05/2003 9:24 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Unfortunately, there's not much selection for us in the 8 bolt wheels. I'm running the 7.50R16 Timberline AT on the rear of my 52. For rims I used Chevy 8 bolt from an early 90's truck, but the setback is so deep I can't put the same wheels/tires on the front. Someone else here, and I can never remember who, is using Dodge rims, which have the correct setback and lug pattern.
Fred 52 3600 69 C-10
#14484 11/05/2003 9:43 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Wally has the Dodge rims. Here's a thread about them. 16" rims
#14485 11/05/2003 10:42 PM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | Yea the set back is the problem try this site ( www.stocktonwheel.com) good luck Bill
Bill 1951 3/4 ton 5 window pick up 1955 GMC 1/2 ton longbed automatic
