0 members (), 145 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
#1448382 04/17/2022 1:06 AM
M Online: Happy
Since installing a PCV system on my '51, 216 I've been tinkering with expected high idle from the planned vacuum leak. Today I started the truck after letting it set for a few days and as is habit I pulled the choke out, hit the accelerator a couple of times and it started instantantely.....as it should. Somewhere in letting it warm up a bit I realized the choke wasn't working. Pull the air cleaner and worked the choke at the carb and the linkage works, but the choke plate does not move....What!
Now, I'm running (what was) a nos Zenith O-10355 listed originally sold as a replacement carb for a 1937 ~ 1942 Chevrolet 216. Never messed with it much since it's worked great since I bought it from CarbKing. Come to find out it's got a spring controlled thermostat choke. At least that's my current guess. If there'a a problem with the spring setup, I'm not seeing it.
Anyone have any other thoughts on why the choke linkage won't actuate the choke plate? No bi-metal strip or bi-metal spring was obvious, just the little spring at the end of the choke plate rod.
RonR
RonR
1970 340 Duster
1964 CJ5
Carburetion specialist
Can you move the choke plate by hand?
Jon.
The Carburetor Shop
M Online: Happy
Yes Sir. It moves freely from the drivers side end of the choke plate shaft.
RonR
RonR
1970 340 Duster
1964 CJ5
Rotate the choke lever like you were pulling the choke, and observe if both ends if the spring move.
That choke coil is very small wire, perhaps it has broken.
Jon
The Carburetor Shop
M Online: Happy
Operator error. That's what I think is going on. The spring isn't broken, however just pulling the choke knob out won't cause the plate to move. Push the accelerator down and pull the choke knob and the choke works as expected. My guess is that all's good and it's been that way all along, I've just never tried to actuate the choke while diddling around under the hood before.
Color me embarrassed, RonR
RonR
1970 340 Duster
1964 CJ5
No need to be embarrassed.
No one is born knowing everything wink
For each mistake corrected, one earns one check-mark.
At 1000 check-marks, one is awarded a degree from UHK a.k.a the University of Hard Knocks. (I won't tell you the advanced degree I possess wink )
Glad you found your problem.
Many chokes, both manual and automatic, have a throttle lock-out to the choke.
Jon
The Carburetor Shop
M Online: Happy
Jon said; "At 1000 check-marks, one is awarded a degree from UHK a.k.a the University of Hard Knocks. (I won't tell you the advanced degree I possess wink )"
Actually, I do have my Masters, if I live long enough I expect to get that PhD. smile
RonR
RonR
1970 340 Duster
1964 CJ5
