2 members (lumbersawyer, JW51), 55 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
Went out to find the casting # on the newly acquired 235 and couldn’t really find one. Nothing long. Looking on the passenger side toward the rear I only found this:
CON 3 L204
The serial # on the flat boss behind the distributor is: OI95I95F55X. (That’s oh eye 95 eye 95 F 55 X). I guess the first character could be either a “zero” or “oh”??
Some of you guys are good at this stuff. I am not, so I appreciate your helping me. Thanks!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
I would say December 54 for the casting date, thus, for the 55 model year.
Mike
OI95I95F55X
OI95I95=engine serial number
F=Manufactured in Flint, MI
55=1955 model year
X= Thriftmaster 235
CON 3 L204
CON 3 = Conveyer #3
L204 = December 20, 1954 manufacture date
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
Mike and Mason, you guys are fantastic! Thank you so much for the detailed answers. I really appreciate your help!
Chuck
1941 Chevy coupe
Casting number should be on r.h. side of block, close the front above oil pan flange. Just ahead of the pump.
BC
1960 C60 pasture art
Here are locations of various head/block codes.
The Engine Serial Number also helps, but, it could have been changed over the years by a good mechanic/machinist.
The hard-to-change codes would be casting codes:
head casting code
head date casting code
block casting code
block date casting code
Here is a "key" for head and block casting codes.
BC and Tim, I found the casting # where you said to look. Every casting # I ever looked for was at the back of the motor. This one was way at the front.
The # appears to be 3835911
Can any additional information be had by looking up this number?
Chuck
1941 Chevy coupe
3835911 is a block casting code for:
Block: 3835911 (235 Corvette after 16 Oct 1953)
Block: 3835911 (235 Truck and & Corvette 1954 & 1955)
Can you see/find your block date casting code? location is shown on Photo on this page.
Stlcardinalsguy (Mason) decoded that one for me earlier…….
THANKS Tim for looking up the block code for me. I appreciate it!
Chuck
Chuck
1941 Chevy coupe
