8 members (66flea, Southerntruck, Otto Skorzeny, GMCJammer51, Phak1, TGP, DadsFirstPickup, Wayne67vert), 118 guests, and 2 robots.
Topics128,049
Posts1,055,682
#14480 11/05/2003 7:20 PM
I have noticed that on the Bridgestone tire site, they have a tire for a light truck that is steel belted, is listed as a 16 x 750, and the recommended rim width is 5.5" . I believe the diameter is around 31" or 32". Now this would be a great replacement for wheels and tires on the AD 1 and 3/4 Tons. I would think that a 5.5" rim width would probably come with a 3.00" backset. Does anybody market such a rim?
1951 1 Ton Completed
#14481 11/05/2003 8:05 PM
If you are interested in after-market rims, check out Summit. They have almost every conceivable rim diameter, bolt pattern, and backset.
#14482 11/05/2003 8:19 PM
check with Canadian Wheel. I bought my rims from them and the service was great.
http://www.canadianwheel.com
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#14483 11/05/2003 9:24 PM
Unfortunately, there's not much selection for us in the 8 bolt wheels. I'm running the 7.50R16 Timberline AT on the rear of my 52. For rims I used Chevy 8 bolt from an early 90's truck, but the setback is so deep I can't put the same wheels/tires on the front. Someone else here, and I can never remember who, is using Dodge rims, which have the correct setback and lug pattern.
Fred
52 3600
69 C-10
#14484 11/05/2003 9:43 PM
Wally has the Dodge rims. Here's a thread about them.
16" rims
Fred
52 3600
69 C-10
#14485 11/05/2003 10:42 PM
Yea the set back is the problem try this site (www.stocktonwheel.com) good luck Bill
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
