4 members (Shardean, Peggy M, klhansen, Eisenholtz), 50 guests, and 5 robots.
Topics128,022
Posts1,055,376
Members48,420
#1447819 04/12/2022 4:46 PM
I took the Rochester Monojet off my 261 before having some engine work done. The carb sat for quite a while untouched. I put the carb back on as is since the carb was working just fine before the engine work (I know, I know.)
I think I lost what might have been a little piece that clamps on the cable sheath. So, is there a little clamping piece that should be attached to the hole with the arrow pointing to it in the pic?
If so, are those little pieces available?
I tried to use a zip tie but that doesn't work.
Thanks!
After digging deep in cans of parts, I might have found something off an old Carter W-1. More later with another pic.
This is what I found with a lot of other stuff. I have know idea from where it came. But the little piece on the end with the bolt should work. I still wonder if these are available.
Might look to motorcycle or bicycle parts for cable/housing stops, lots of options from their brakes and shifters, a clamp onto the side of the housing would be way down on the list of choices, in my view a true housing stop is much more reliable than a side clamp, ie: it does not compress on the side of the housing.
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Curmudgeon
Curmudgeon
I see two Bowden cables. One for choke the other maybe hand throttle?
The Monojet throttle lever was designed to connect to a throttle cable or a link from a bell crank.
Your engine has a throttle rod so I guess it was modified to work somehow.
A spring goes where your black arrow is shown.
You may be missing a choke link.
Wally,
If you search on the net "Throttle cable housing clamp", you're bound to find what you need.
Craig
