1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
My 1948 Chevy ½ ton truck served as a county road department vehicle in the high desert of Nevada. The previous owner replaced the original 216 c.i. engine with a rebuilt 1955 235 c.i. truck engine. The original radiator is long gone. The current radiator in use is a Harrison, stamped R-11 with 49A (1949 January production) on the driver side. The passenger side is stamped 3118967. The radiator cap is an after-market that reads DO NOT OPEN HOT and OPEN SLOWLY. They all work well together–no complaints from me. I hope I am not jinxing myself with this post!
I am striving for originality. What radiator and cap would this truck have left the Oakland assembly line with April 1948? Would a work truck in the Nevada high desert been outfitted with a different radiator and cap? What radiator and cap would the 235 c.i. truck engine been paired with coming off the assembly line in 1955?
Revisit your part number on the radiator tank and see if the last number isn't an '8'. If so you have a replacement radiator one year newer than your truck.
What's the build month on the truck (part of the cowl serial number)? The only difference in what you have 3118968 and what you're looking for is the date code. The radiator date code should be the same month or a month or two older than the truck assembly date code to be correct in high point judging.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
My truck is an April 1948 build in Oakland. #s on the replacement radiator are as listed in original post.
The part number you list (3118967) is not found in any of my parts books, so I won't be any help in ID'ing what it came out of...the correct radiator part number for your truck is 3118968 if that helps.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
How can you be striving for originality when you have a 1948 truck with a 1955 engine? At this point what difference does it make what the part number on the radiator is? The most important part under the hood (the engine) is already incorrect so worrying about what radiator is "correct" seems pointless.
1950 Chevrolet 3100 (Ol' Roy)
I am simply trying to learn something new, and perhaps someone else can benefit from the information as well. Knowledge is power!
Curmudgeon
Curmudgeon
1948 1/2 ton truck w/ 216 engine. Radiator had a 0 psi cap. Double ear.
1955 1/2 ton truck w/ 235 engine. Radiator had a 4 psi cap. Double ear.
General wisdom is that old radiators can't take a lot of pressure and may rupture.
If what you have is working well, general wisdom says, don't mess with it.
The 1950 Chevrolet MPL (Master Parts List) calls for a radiator 3118968 for 1947-50.
Harrison could have made a radiator 3118967 that fit Chevrolet trucks and other applications.
Harrison stamped the number in the upper radiator tank, not GM, so a Harrison radiator manual is needed.
