| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2022 Posts: 52 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 52 | Hello all,
Has anyone done this yet? Any pictures and recommendations on belts? | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I installed a set of seat belts plus shoulder belt about 15 yeas ago. I think they came from Seat Belt Pros. I don't think they are still in business. They are like most of the aftermarket ones, an aircraft type buckle in the center with a self retracting inertia type on the other side. They came with mounting hardware. They are bolted to the floor behind the seat and I added a square of 1/8 steel plate to the underside the floor for a better anchor. For the shoulder belt anchor I welded a piece of 2x2 square tubing to the rear body seam behind the seats and fastened the shoulder anchor point to that. This results in an anchor point that is maybe a little low but is certainly strong. Probably doesn't matter but I have bucket seats. I'm not one for taking a lot of pictures, If you need i can see if I made some.
Harold Wilson 41 Chevy 3/4 Ton
