4 members (Shaffer's1950, Gray_Ghost, bucktruck, walter74), 84 guests, and 4 robots.
Topics128,129
Posts1,056,700
Members48,454
#1447599 04/10/2022 11:07 AM
Hello, how do you remove the torque tube from the back of the transmission on a 53,3 speed manual transmission? Thanks.
1953 with a 216
Leo Offline
Moderator
Moderator
You need to unfasten the threaded collar, that allows you to slide the spherical housing back. This exposes the U joint, unfasten that and you can drop the torque tube enough to remove the transmission. Be sure to keep track of any shims that are there for correct alignment.
AD Addict & Tinkerer
Prior to sliding back the housing, you will need to clean and emery the part that slides, so it is squeaky clean otherwise you will have a difficult time getting it to slide back.
Here is the section that covers the removal from the Chevrolet Truck Shop Manual.
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0449.html
Phil
Project Journals
Stovebolt Gallery Forum
Be sure the weight of the vehicle is supported by the frame, NOT the rear axle tubes. Weight on the springs can, and usually does cause the torque tube to slam down as the U joint is disconnected. This happened to a friend back in high school, and one jack stand slipped out of position, pinning him under the vehicle. Only minor injuries resulted, but it took three people to lift the vehicle enough to get him out from under it. It's also a lot easier to slide the pivot ball back with no load on the torque tube.
J M Offline
They call them torque tubes for a reason. Years ago I took one loose and it came down just past my ear. It got my attention real quick. Now I always put a chain around it and tie it to the truck. It took only once for me to learn that lesson. I guess the school of hard knocks was in session. Luckily I wasn't hurt.
Jim
Thanks I was going to say tie strap it up or chain it up so that doesn't happen.
1953 with a 216
Jim
A 2x4 fit between the frame rails, under the torque tube works real well too!
Phil
Project Journals
The 2x4 trick is by far the simplest option. The further you slide the 2x4 rearward in the frame, the higher it moves the tube out of your way.
52carl We had a greaser of a 2x4 cut to length for that.
Patina is what you call that. smile
That helps to remember not to use that one for building a shelf or whatnot.
