2 members (DadsFirstPickup, Stovebolt48), 97 guests, and 1 robot.
Topics128,050
Posts1,055,670
#1446203 03/27/2022 10:29 PM
I am replacing my master cyl and the bolt that connects the mc to the break arm is old and worn. Is there a replacement available? This bolt has a eccentric on it to adjust the arm or i would just use a regular shouldered bolt. any advice ?
Try this place. It is for a Ford but may be the same or maybe they can match one for you. Also, call JC 800-862-1913. He may have some used ones.
Harold
https://shoebox-central.com/1949-1950-1951-ford-eccentric-brake-pedal-adjustment-bolt
https://www.pre60s.com/product/eccentric-brake-pedal-bolt-ford-mercury-1949-1951-3/
Harold
Harold46 #1447274 04/06/2022 11:07 PM
Thank you. looks like the shipping is more than the bolt. Will try jc and see if he has a used one.
