| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 3 Moderated | | Moderated Joined: Jul 2021 Posts: 3 | Hey all. Only being a bolter for less than 2 years, we have limited experiences. This past sun we picked up a 40 parts truck. Only the front half of the truck. While we were looking at parts we found what turned out to be engine splash pans. Our 40 doesn't have them and non of the old trucks we had seen did either. so these appear to be an original item that rarely survives as do many other parts. They are in remarkably good condition, compared to the rest of the truck is. Any info anyone has would be appreciated. Does anyone have these on your trucks now? As always, another suprise in the world of bolting. Thanks, Chuck n Pat | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | My 41 truck still has them.
Engine side splash pans were originally installed on all of the deco model trucks. They help with allowing the fan draw air through the radiator. Unfortunately, they make working on various parts of the engine a real PITA so most were trashed when the trucks received different engines. Good find! | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Had them on my 1939 216. Paul is correct in that they are a PITA when working on the engine. They did a great job as debris shelves. I removed them. I see no difference in engine temperature, but then I do have a 6-bladed fan that helped tremendously keeping the engine cool.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | I have them on my truck…..
They fit well and have no problems…. That I know of… 😀
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | missing a lot of other things but my '37 has them.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
