3 members (68ironhead, Pre '68 Dave, Shade Baby), 81 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#1446879 04/03/2022 12:11 PM
6 heaven
6 heaven
How would an AD body fit onto a task force frame? Basically, would a 50 -54 body fit onto a 56-59 frame fairly easily? Seems like maybe an easy "upgrade". You would get better 6 cylinder engine and open driveline and Bendix brakes.
Curmudgeon
Curmudgeon
A 56ish front TF suspension was bolted/welded to an AD frame.
The tires were rubbing the fenders.
It is easy enough to do the Bendix upgrades, and the improved full pressure, inert bearing engine swap on an AD chassis.
The Task Force truck drive train is not a vast improvement over a '54 AD, not to mention the front wheels will hit the front fenders. ( I guess I just did mention it, but nevertheless...)
6 heaven
6 heaven
Thanks! Do you mean the width will cause a problem with rubbing, or will they rub on the front fender or rear fender?
Curmudgeon
Curmudgeon
The rear is okay.
From diagrams:
1956 front 60.52"
1954 front 57.03"
60.52-57.03 = 3.49"
Divided by 2 = 1.745"
The edge of the tire is 1 3/4" closer to the fender.
Appearance wise it is a little noticeable.
Turn steering wheel to maximum left (as an example).
Now hit a pot hole where the front axle goes up.
The problem can be worse if you are running wider modern tires.
