5 members (Hanks custodian, KEVINSKI, Southerntruck, Gray_Ghost, Hotrod Lincoln), 148 guests, and 1 robot.
Topics128,162
Posts1,056,932
Members48,458
#1446917 04/03/2022 9:40 PM
I have a 51-53 (not sure of the year) chevy chassis 1/2 ton, I picked up for parts, and it has an extra set of leaf springs mounted above the rear axle. They are approx. 3 feet in length, frame bumpers are there too. Were these a factory option, an aftermarket thing, or is this chassis a different tonnage? Also is there any value to this setup as I wont be using it and would rather see it go to a new home rather than the scrap pile.
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
In 1952 (trucks) a heavy duty set of rear springs was available as RPO-254.
1952 Chevrolet Trucks RPOs.
It had 8 leaves instead of the standard 7-leaves-pack.
Last edited by tclederman; 04/04/2022 12:12 AM. Reason: mistyped the RPO number - thanks buoymaker
Curmudgeon
Curmudgeon
RPO-254 maybe?
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1410998.html
There are added springs for extra loading that function all the time.
There are springs that do nothing until the weight on the rear is heavy enough to make contact.
There are low cost add-on non GM versions.
There are junkyard coil springs added (welded on) because the old leaf springs are sagging.
Old work trucks can see almost anything in their lifetime.
The stock 1/2 ton without spring options will have 8 leaf rear springs gm part number 3683317 (please verify).
Leo Offline
Moderator
Moderator
I had a set of those on my '53 3100 panel. I got 50 cents a pound for them.
The second picture from Buoymaker is the set-up that was on this Frame. I guess they're headed for the scrap pile. Thanks for the info
1952 GMC
1967 GTO
1967 Firebird
Curmudgeon
Curmudgeon
On the farm with a load of hay, rocks, fertilizer or pulling a trailer, those springs come in handy.
It can keep the tongue from bottoming out in a situation where there is a ditch or a depression in a paved parking lot.
They are still used on new trucks today by people who pull a ski boat or a trailer loaded with a tractor.
