1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | What is the best way to touch up small nicks on a chrome bumper. And what paint is best to use | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | dougs From what I read they make a paint that will help a lot on chrome touch-up,think eastwood may carry it. | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | I remember some kind of electromagnetic brushes and compounds that were sold years ago that created chrome on touch up spots. Not sure if they still exist or even worked. 1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | My 2 pennies.
If the "small nicks" are residue from whatever contacted the chrome on the bumper, use very fine steel wool to remove it.
My experience is that paint doesn't adhere to chrome. The chrome surface has to be chemically treated or maybe sandblasted.
There are small bottles called "liquid chrome" and other like brands. It's basically shiny paint with a small applicator that may hide small scratches for a time. I think the idea is that if the chrome surface has been penetrated, you can dab the paint down into the crack or nicks and the paint will adhere to clean steel. It may help the bumper look less noticeable. With close examination you can still see the repair.
There is a paint called chrome which is maybe a notch above aluminum paint as far as the shine or reflection of light. It doesn't have the deep chrome look but is "somewhat tolerable" if used for the whole bumper. The surface has to be prepped just like regular paint. Be prepared it takes a very long time to dry so don't spray it on too thick.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
