5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
#1446755 04/02/2022 4:10 AM
Walked around the shop earlier tonight and did some counting. THIRTY FOUR battery chargers for everything from a circular saw to a belt sander. Two 220 extension cords for welders and plasma cutter, ONE 110v extension cord, and two 50' air hoses. If not for tires and air guns the hoses would be extinct. The tool world is changing.
Evan
Evan,
Wait until you get one of these. We'll do medium duty trucks all day long. hook it up, push a button, walk away and do other stuff!
Inflator
Looks good, Evan
The unit you linked-to has non-rechargeable battery pack.
They have another "model" that comes with the rechargeable battery pack (battery and charger).
Do they have other items/tools that use that battery pack?
[I looked further, and this might use a Milwaukee M12 12-Volt Lithium-Ion XC - a variety of other Milwaukee and Hitachi tools use that "system".]
If Evan buys this, he will most likely increase his number of battery-packs/chargers?
Please correct me, if I am wrong (I will then edit or delete this post).
I use that same battery pack for small impacts, screwdriver guns, stapler, etc.
Just a few years ago I had three air compressors in my air systems. A 10 hp compressor threw a rod recentlyand I haven't replaced it. Except for riveting and airing up truck tires, we just don't use much air any more. Most of my pneumatic tools are just collecting dust.
https://photos.app.goo.gl/AiLvLPiRKwS7f15w6
I use all Metabo cordless. I keep several of their 8 ah batteries charged up at all times. I don't think a person can drill enough holes in a day to run a battery down.
https://www.zoro.com/metabo-180v-li...80ah-lihd/i/G6244222/?q=metabo%20battery
https://photos.app.goo.gl/ra8LNMCGgFbkECPDA
Metabo 18V Cordless Tools battery is compatible, too
Yesterday, I had the fine opportunity to work on my wife's car. Front catalytic converter, front brakes and new struts. The only time a cordless came out, was for the top nuts on the struts. Only because it called for the 3/8" drive, 90 degree Milwaukee impact ratchet. And I started nut removal with a regular ratchet to loosen them up. I was too lazy to remove the wipers, to remove the panel that covered the top of the struts. Otherwise, it was all hand tools and air tools. 1/2" IR impact to be specific. Probably because I don't have a cordless 1/2" impact and I didn't want to lug around the 3/4" cordless impact.
Air tools still have a ton of life in my world, especially die grinders and sanders. Most likely because I wrench full time, for a living.
Moderated by  MNSmith
