| | | Forums66 Topics128,069 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 193 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 193 | About 10 years ago I was finally able to source the trans gear to activate my speedometer. I replaced the broken head with a good used unit, new cable and housing. My problem today is the needle is fluctuating 20-30 mph, sometime settling on a average speed. 1946 half ton with a 4 speed trans. I am familiar with old mechanical speedos chattering when the cable needs lube, is this the same issue? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I like to use Lubriplate white lithium grease on a speedometer cable. If there happens to be a tight bend anywhere in the cable housing, it's possible for the inner cable to wind up and snap forward repeatedly, causing a chatter of the speedo needle. Jerry
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I find I can overtighten the cable at the speedometer and it does crazy things. I then back off a smidge. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | Mine bounces terribly. Do you disconnect completely and then clean and lube it?
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Most drive cables can be pulled out of the housing from the speedo end, no need to disconnect at the transmission. Give the cable a good wipedown with a solvent-soaked rag, and coat it with fresh lube as you reinsert it into the housing. If that doesn't improve things, and there's no tight bends in the housing, there's probably some roughness inside that the drive cable is hanging up on. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The two easiest things to do are clean & lube as Jerry recommends and not over tighten the connection as the speedometer as Wally noted. Either or both of those can make the needle bounce. My experience has been that a lube issue usually presents as chattering as well as bouncing. While I've not personally experienced it, I've been told by a speeo rebuilder that a worn/damaged drive gear can produce bounce as well.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Tiny I think over the miles the cable wears a trough in the housing that can get dry and chattery. If you recall there used to be an old guy at the swap-meets that had a display of a smoot running speedometer,he sold a special lube for them . Mine runs OK but the hand rubs on the glass,at about 50 it's pretty smooth for 71 yrs. Also the 2-speed switch-over is fine. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | JW51 do that then run it carefully with your battery drill from below to see if it's smooth. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | We used to have a tranny guy that would come and assemble your clean automatic transmission,he seldom missed. He commented that graphite wouldn't work on the speedo cable,chatter. | | | | | Joined: Aug 2009 Posts: 193 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 193 | So here I am a month later! I posed my original question because I was familiar with old speedo cable chatter and some slight vacillation when the cable needed lubrication. My needle was waving at me! A bounce that would vary to about a 50 mph spread and it became worse to the point that the needle pegged to max and back. I agreed with everyone suggesting lubrication, but was just sending out feelers for other possible issues. Having been in the business, I still have a half-used one gallon container of Lubriplate and finally got off my butt. The housing was so dry, that lubed the cable 4 times, back and forth until it went back in. SUCCESS!! Thanks for your input. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 46 Texaco On my shelf is a half used I think 1/2 gallon can of lubriplate that is so old the can is an antique. Need to get it down and grease mine too. Also have a 5 lb. roll of dutch boyrosin core solder half gone has the dutch boy right on it. I thought the other day maybe it is gonna get me thru !! | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | We used to have a tranny guy that would come and assemble your clean automatic transmission,he seldom missed. He commented that graphite wouldn't work on the speedo cable,chatter. I've been told that graphite will actually make the problem worse.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | While we’re talking about removing the speedo cable for maintenance, what size brass knurled thumb nut do I need to buy for the actual speedometer? I’ve read where they make the job of taking the head out and reinstalling it much easier. Thanks
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2014 Posts: 4,483 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,483 | Chuck, if you have the speedometer removed from the truck it is not difficult to remove the speedometer mechanism and clean and re-lube it. A few years ago I posted instructions on how to do this. The main and most important thing is to be really careful removing the needle. The needle may not want to come off and you may break the shaft removing it. You can isolate the needle with very thin pliers or a hemostat, but even doing that won't guarantee you can avoid problems.
But then I came back and explained with images how you can repair/restore that broken shaft using easy to find brass tubing from K&S Co. Sadly we're not adding to Tech Tips these days, but maybe you can find my post on repairing the shaft and oiling the speedometer. There is also a post I made on renovating the odometer wheels (along with free printable images you can use with waterslide decals or double-sided adhesive) and instructions on how I do that.
Most of these speedometers don't seem to be worn out nearly as much as dry and lacking lubrication. The ones I've seen simply need to be revived a bit. Sorry, but I can't recall offhand the size of the thumb nut. Offhand I think it is 5/8"/18 thread at the speedo head but you should check me on that.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I use 10/32 knurled nuts on my instrument gauges.
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | |
