| | | Forums66 Topics128,095 Posts1,056,077 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2021 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 20 | Back with another question (and of course, its to do with brakes)
Been working on my 5500 trying to get everything working so that I can actually drive it and do some work, but the drum brakes just have refused to work for me thus far. I've been thinking about making an "upgrade" to disc brakes what I really want to know is if 1. this is worth it and 2. is this possible without having to fabricate my own parts. I'm probably going to make a post showcasing the truck so far on what my family and I have done with it so far, but having to take a break to wait for money and plan ahead for future projects with this truck
thanks again for any info! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | What year is your truck? You're the only one that knows if adding anything to your truck is worth it...with enough time and money, anything is possible! Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What is your wheel bolt pattern?
Ed
| | | | | Joined: Dec 2021 Posts: 20 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 20 | 1. truck is 1972 2. 10 lugs in the back dullie. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | You will probably end up spending far more money converting to disc brakes than rebuilding the original system to brand new condition will cost. Grigg has spent a lot of time and effort writing a tutorial about converting to modern axles with disc brakes, which is probably the only safe, effective way to do it. Get ready to do somer CPR on your checkbook! Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | So is your bolt pattern 5/10 front/rear? Is it 10 on 7.25, 10 on 8.75, or larger?
Ed
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | GMC dumptruck72 Hotrod Lincoln is right your brakes repaired back like new will do the job ! Not cheap but a lot better than a crash ! My 51 6400 will slide the tires on a hard stop,only ABS can do better !! | | |
