1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
Back with another question (and of course, its to do with brakes)
Been working on my 5500 trying to get everything working so that I can actually drive it and do some work, but the drum brakes just have refused to work for me thus far. I've been thinking about making an "upgrade" to disc brakes
what I really want to know is if 1. this is worth it and 2. is this possible without having to fabricate my own parts. I'm probably going to make a post showcasing the truck so far on what my family and I have done with it so far, but having to take a break to wait for money
and plan ahead for future projects with this truck
thanks again for any info!
What year is your truck?
You're the only one that knows if adding anything to your truck is worth it...with enough time and money, anything is possible!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
What is your wheel bolt pattern?
Ed
1. truck is 1972
2. 10 lugs in the back dullie.
H Online: Content
You will probably end up spending far more money converting to disc brakes than rebuilding the original system to brand new condition will cost. Grigg has spent a lot of time and effort writing a tutorial about converting to modern axles with disc brakes, which is probably the only safe, effective way to do it. Get ready to do somer CPR on your checkbook!
So is your bolt pattern 5/10 front/rear? Is it 10 on 7.25, 10 on 8.75, or larger?
Ed
GMC dumptruck72 Hotrod Lincoln is right your brakes repaired back like new will do the job ! Not cheap but a lot better than a crash ! My 51 6400 will slide the tires on a hard stop,only ABS can do better !!
