8 members (J Lucas, klhansen, Tronman, electors, 78buckshot, cmayna, JW51, 1 invisible), 73 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#1445702 03/24/2022 2:04 AM
Gents,
I just fabricated new vertices throttle linkage for my 261. It goes from the pivot point up to the carb. I used 1/4” x 28 rod with 2 heim joints on the ends. Now I have an adjustable rod!
Thanks for the tip Cosmo!
Chris
ndkid275 #1445744 03/24/2022 1:07 PM
Nicely done Chris! Looks professional.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
ndkid275 #1445896 03/25/2022 2:53 PM
I like that a lot.
What size is the bolt on the Heim joint? Is it 1/4 as well?
1951 3100
ndkid275 #1446181 03/27/2022 5:49 PM
ndkid275 Good Job Can make shifter linkage the same way,bend to fit.
ndkid275 #1446478 03/30/2022 3:36 AM
Everything is 1/4”
ndkid275 #1446502 03/30/2022 2:25 PM
Nice!
When I did my 261 with a Rochester Monojet I bent a rod. I think there were 5 bends in it. I like yours better.
ndkid275 #1446555 03/30/2022 9:34 PM
Wally
Mine sits 1/2 off the manifold straight and I can lengthen or shorten it to get the full range of throttle and adjust my peddle slightly. I thought that this was easier than attempting to bend rods.
Chris
ndkid275 #1446657 03/31/2022 9:05 PM
Yours is much better.
ndkid275 #1448331 04/16/2022 5:46 PM
Very nice idea, I like that a lot!
