0 members (), 329 guests, and 3 robots.
Topics128,168
Posts1,057,100
Members48,463
Former Workshop Owner
Getting ready to change the oil in my '69 C-50 350 V8 that's presently equipped with the canister type filter. I went to Advance Auto, OReilly's and NAPA with NAPA being the only source (of these 3) that could locate one and it's in Boston. The guy wasn't even sure that it was the one that I need and shipping cost (about $12.00) is not refundable. I really don't want to take it apart unless I have what I need to put it back together. Otherwise I'd get the old one out and try and cross reference it.
That's when I thought what the heck, I'll just install an adapter so I don't have this hassle in the future. Rather than inquire again at the auto parts stores, I thought I'd just do my own research online. Many different brands, several styles and prices out there.
My biggest concern was I came across an article in a forum (not Stovebolt) that said the adapter for the truck engine is not the same as one used on a typical sbc. Is this true? I did notice that the canister on my truck looks way larger than the one I remember having on my '67 Chevelle with a 283.
FYI: I did search this topic before posting but didn't find the answer to my specific question.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
The housing might be taller, but the diameter of the filter housing won't change. There was a 1 1/2 quart canister filter that was used on some of the bigger trucks that used a taller filter cartridge, but it was the same diameter as the passenger car item. If you want to remove the cartridge to check for a part number, nothing would prevent you from either reinstalling the old filter, or simply replacing the empty canister until you can source a correct cartridge. The engine won't know the difference.
A lot of the newer cars are going back to a canister type filters as they are easier to dispose with no metal housing.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I think I may have found the canister filter I need. Rock Auto had an actual part number listed online and O"Reilly has one here in Omaha. It's described as a 2-quart filter. I'll post the part number if it's the correct replacement.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
1 Offline
WIX 51503, or Fram C31PL are part numbers for the tall "Senior" style oil filters. They should be available from lots of sources, including Amazon.
WW2Chevy
1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
Your filter canister is probably an AC S-2. It takes the 51503 filter that was posted. I got one from Amazon for about $15.
JLucas As I recall the 366 big block trucks had that tall filter.
7
7 Offline
I have had no problem ordering the cartridge from Summit, AC filter. The big truck spin-on was an AC 932 I think but they fit all the Chevy V8's. Summit also had them when I needed it.
Big Bolt Forum Moderator
my 58 viking 60 (engine is a 67 327, out of a truck) has the tall canister type, and it is a Napa Gold 1129, or WIX 51129 https://www.amazon.com/1129-Napa-Gold-Filter-51129/dp/B01MUF6G1R
Mike
That's the one (WIX 51129) I picked up last night at O'Reillys. The truck is outside, so I'm waiting for the weather to improve.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
(WIX 51129) Confirmed. Exactly the same as the one I removed. No part number on either.
Thanks for all the replies.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
J Lucas Your pictures sure bring back a lot of familiar stuff,back when things were simpler !!
