0 members (),
97
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I’m looking for a picture or dimensions of the bracket and link that connect the clutch pedal return spring to the engine block on a 57 Chevy 1/2 ton with a V8 and heavy duty 4 speed. I have looked at the picture in the factory service manual, but I haven’t been able to locate the parts so I want to make something.
Thank you, Larry | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Larry, The factory assembly manual Section 6 Sheet 2.00 shows an L bracket from the oil pan approximately just below the location of the #5 spark plug. I personally have mounted a bracket on the steering box as it is more directly in line with the clutch linkage. Either way would work fine. Fred
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thank you, Fred. I’ll try that.
Larry | | |
