0 members (),
144
Mod | | | Forums66 Topics128,285 Posts1,058,275 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,429 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,429 | Getting ready to change the oil in my '69 C-50 350 V8 that's presently equipped with the canister type filter. I went to Advance Auto, OReilly's and NAPA with NAPA being the only source (of these 3) that could locate one and it's in Boston. The guy wasn't even sure that it was the one that I need and shipping cost (about $12.00) is not refundable. I really don't want to take it apart unless I have what I need to put it back together. Otherwise I'd get the old one out and try and cross reference it. That's when I thought what the heck, I'll just install an adapter so I don't have this hassle in the future. Rather than inquire again at the auto parts stores, I thought I'd just do my own research online. Many different brands, several styles and prices out there.
My biggest concern was I came across an article in a forum (not Stovebolt) that said the adapter for the truck engine is not the same as one used on a typical sbc. Is this true? I did notice that the canister on my truck looks way larger than the one I remember having on my '67 Chevelle with a 283.
FYI: I did search this topic before posting but didn't find the answer to my specific question.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2004 Posts: 29,933 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,933 | The housing might be taller, but the diameter of the filter housing won't change. There was a 1 1/2 quart canister filter that was used on some of the bigger trucks that used a taller filter cartridge, but it was the same diameter as the passenger car item. If you want to remove the cartridge to check for a part number, nothing would prevent you from either reinstalling the old filter, or simply replacing the empty canister until you can source a correct cartridge. The engine won't know the difference. Jerry
| | | | | Joined: Sep 2010 Posts: 2,354 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,354 | A lot of the newer cars are going back to a canister type filters as they are easier to dispose with no metal housing. | | | | | Joined: Nov 2004 Posts: 2,429 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,429 | I think I may have found the canister filter I need. Rock Auto had an actual part number listed online and O"Reilly has one here in Omaha. It's described as a 2-quart filter. I'll post the part number if it's the correct replacement.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | WIX 51503, or Fram C31PL are part numbers for the tall "Senior" style oil filters. They should be available from lots of sources, including Amazon.
WW2Chevy 1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
| | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Your filter canister is probably an AC S-2. It takes the 51503 filter that was posted. I got one from Amazon for about $15.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | JLucas As I recall the 366 big block trucks had that tall filter. | | | | | Joined: Feb 2016 Posts: 2,008 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 2,008 | I have had no problem ordering the cartridge from Summit, AC filter. The big truck spin-on was an AC 932 I think but they fit all the Chevy V8's. Summit also had them when I needed it.
| | | | | Joined: Nov 2004 Posts: 2,429 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,429 | That's the one (WIX 51129) I picked up last night at O'Reillys. The truck is outside, so I'm waiting for the weather to improve. John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 2004 Posts: 2,429 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,429 | (WIX 51129) Confirmed. Exactly the same as the one I removed. No part number on either.
Thanks for all the replies.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | J Lucas Your pictures sure bring back a lot of familiar stuff,back when things were simpler !! | | |
