4 members (HandyAndy, klhansen, Gdads51, 52Carl), 103 guests, and 2 robots.
Topics128,062
Posts1,055,847
Members48,428
#1445457 03/22/2022 6:12 AM
What are the differences between the front axles and rear axles of the single rear wheel 3800's and the dually 3800's?
Did the front axles have a different hub, or was it the same axle as a single rear wheel 3800 but with an adapter bolted on to move the mounting surface out?
I'm also curious about the rear axle. Was the hub the only difference, or was the axle narrower or wider than the single rear wheel version?
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
2 Offline
A while ago I tried digging through parts books to figure this question out
I think the only difference on the rear axle is the studs pressed into the axle are longer to accommodate the extra thickness of two rims
And I need to track down a set of these longer studs for one on my trucks
The front axle I’m not sure as my dually lost it’s special dually front bits long ago and is single wheel style on the front now.
But i also look forward to the definitive answers that hopefully will follow.
-s
3B Offline
Hy whateverpratt, the dually front axle hub is a one piece unit and is obviously different than the single wheel front hub, there is no "adapter" to space the dual wheel out. As far as I am aware the rear axle is the same for either single wheel or dual rear wheel application. the only exception is the one noted by 2ManyTrucks, longer wheel mounting studs for the dual rear wheel application, hope that helps
Thanks guys, that's what I was looking for
Moderated by  Dusty53
