| | | Forums66 Topics128,184 Posts1,057,195 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2022 Posts: 51 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 51 | Hello Everyone,
Just had a quick question to see what folks would recommend for flushing my SM420 transmission before I install it.
I drained it out and the fluid was pretty thick.
Also noticed there are two plugs, which I assume the one was the drain and the other a fill plug. They didn't seem to be that far apart and so I just want to make sure you only fill it with fluid until it pours out from the higher side plug or do you fill it some other way.
Lastly what type fluid and what viscosity should I use.
Thanks for the help.
Scott | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It can be flushed using diesel or kerosine, no load, just run in place for a while.
Ed
| | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | What Ed is saying is, get both back tire off the ground and fill the tranny with diesel. The side plug is your fill level. Run the truck in second gear for a minute or two. Drain and fill with 90 weight gear oil till it starts to come out the side plug. The fill level does seem low, but it get the lower gears in the lube and splashes the rest of the gears and bearings for lubrication.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2022 Posts: 51 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 51 | Thanks guys
Right now it's not installed so I guess I can either wait to flush it out after I install it or maybe figure out how to turn the shaft while in gear.
Maybe what I can also do is turn it sideways where the side plug is face up and fill it with diesel and just let it soak for a few days and then pour it out.
What do you guys think.
Thanks Scott | | | | | Joined: May 2015 Posts: 11,164 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,164 | If you have a large drill chuck, you could possibly connect it to the input shaft and spin the transmission for the rinse cycle. But letting it soak in diesel would help, just not as much.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Gasoline is a better solvent if you can park it somewhere outside, in the sun if possible.
Ed
| | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | When I had my tranny out of the truck for a clutch job I pulled the side cover and top cover, splashed some gasoline in it a couple of times. Refilled with Valvoline MT manual trans fluid. Shifts like a dream.
| | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | When filling the gearbox with oil, I simply remove the shifter and pour into it's hole. Way much easier versus filling via the side plug. I still use the side plug to check oil level though.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2022 Posts: 51 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 51 | Thanks everyone for all the good tips.
That should take care of this one.
Anyone know of a shop that rebuilds original starters.
I have an original 6 volt starter that I want to make 12volts and also change the flywheel engagement to work with a 1956 235 engine flywheel.
Thanks again for all the help. Scott | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | No need to change the 6 volt starter, just don’t lay on it. That way you can continue to use your existing flywheel. 12 volt starters require a different flywheel.
Ed
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | 6 volt starter will last forever on 12 volts if you don’t crank excessively. Plus, it will crank faster.
| | | | | Joined: Mar 2022 Posts: 51 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 51 | Hi Ed,
I have heard that you can use a 6volt starter in a 12volt setup.
The truck was a 51 but the engine was a 56 235, I think the starter is potentially from the original motor but not sure.
I read that if the tag is black (which mine is) that its 6 volts and I thought by 56, all the starters were 12 volt.
Just trying to figure out the correct combination of teeth are on the starter drive gear and how many teeth on the flywheel to know that I have the right configuration.
If not, can I just rebuild my starter and change that gear to match (starter being original it probably should be rebuilt, even though I tested it and it spins).
Seems easier than tracking down a new flywheel just to use with an old starter.
Thanks again Scott | | | | | Joined: Jan 2022 Posts: 2,493 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,493 | I agree with Ed. I've put 40,000 twelve volt miles on my GMC 228 with its stock 6v starter. But I never crank it for more than 5 seconds at a time. Spins real fast. Starts quick.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
