9 members (Bogart's Truck, Donf, jmoore, Gdads51, TexasA&M48Truck, Otto Skorzeny, Frank50, 2 invisible), 103 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
#1444617 03/14/2022 8:13 PM
If you have, or are looking for, a 235 motor that has the water pump in the “high” position, can someone tell me the distance the top of the water pump would be from the thermostat housing? Seems that would be an easy way to tell if the motor would be a good candidate for a transplant into a 47-53 truck. A picture would be nice too. Thanks
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
I believe it’s like 3-4”. We can measure it using the plate and pump I have for you. Someone might be able to give you exact specs.
Can’t wait to see your truck back on the road!
Chris
Edit: pump is 3-4” higher. Not sure the actual distance between pump and thermostat housing.
I’m going to measure the distance over the weekend and will report it here.
Chuck
1941 Chevy coupe
The shape of the entire front of the block is different. Ray Charles could tell the difference in an early and a late model engine.
Then I guess I’m not as smart as Ray Charles. I do like a good challenge though!
Chuck
1941 Chevy coupe
Ray may be able to tell the difference, but we can't without photos. Do you have both types of blocks in your collection that you could post side-by-side pics of?
Early engines have 2 smaller holes at the front of the block that the pump & cover plate bolt to high mount pump. Later engines ('55 , 55.1 & up) have one larger hole at the front of the block, the pump mount into with 4 bolts to the block.
BC
1960 C60 pasture art
Another quick way to tell is, the high mount water pump shaft is at the same level as the head gasket. The low mount pump shaft is about 3” lower than the head gasket.
My Blog
Okay, as promised I measured the distance between the top of the water pump housing and the bottom of the thermostat housing and it was between 7/16” - 9/16”. Basically 1/2” gap between the two points. Pre ‘68 Dave’s comment is spot on…… the shaft of the water pump is exactly in line with the head gasket. Now I know all I have to do is look at the water pump shaft to tell if the pump is high or low.
Chuck
1941 Chevy coupe
