1 members (KEVINSKI), 160 guests, and 2 robots.
Topics128,108
Posts1,056,230
Members48,436
#1442837 02/27/2022 3:51 PM
Moderated
Moderated
Hi all , New member here, hoping for some ideas, I have a 63 Fleet side 350 sbc older restoration and would like to upgrade the front-end suspension and add disc brakes. I thought I heard that there were some later model control arm /spindle/ disc brake bolt on conversions hoping to keep the same height.
Insomniac
Insomniac
Did you read this: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1439568/anti-sway-bar-info.html
We had a '63 pickup with the 292. I thought it handled well except It did roll quite a bit with a heavy Caveman camper in the bed.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I highly recommend buying a disc brake kit from CPP. Drop spindles is available as well as stock height. I’ve used the kit on both of my trucks.
The 1973-87 front crossmember and suspension will swap under your truck. That will give you 5 lug disc brake rotors. You will also be swapping in 30+ year old parts. It all depends on your standards and how much labor you want to tackle.
These trucks already have modern suspension. Upper lower control arms. Trailing arm independent suspension in rear. Only real upgrades i see are adjustable spring shock combos and sway bars.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Unconventional Thinker
C10? C20? I bought the C20 disc brake kit from CPP, and ended up throwing 50% of the parts in the trash because they were inferior product. The only thing I used from the kit was the calipers, spindles, backing plate and rotors. I had to buy new ball joints, the ball joints provided in the kit were junk, maybe 20% of the threads caught on the castle nut and ball joint stud. One hard bump and the whole thing would have come apart, if they could even be torqued to spec to begin with without stripping the nut or stud. Tie rod ends and adjuster sleeves were no no good, the bearings were cheap chineseium. I couldn't use the brake lines they provided either. For a $900+ kit back in 2005, I ended up spending close to that in replacement parts to get a solid it that would be safe on the road. I wouldn't recommend CPP because of my experience with their C20 kit, but maybe their quality is better now, or their C10 kit is good quality.
Converting to front disc was definitely worth the hassle in the end, the truck stops really well compared to the 4-drum setup. If it were me I would find a donor truck and swap in the front end from a 73-87 Chevy truck. I didn't know that was doable when I bought my kit, had I known that, I would have gone the donor route instead of the CPP route.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
