1 members (RLB), 101 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#1443442 03/04/2022 7:36 PM
Rustbucket Ranch
Rustbucket Ranch
Hey guys, so I'm getting back into trying to get the 261 in my '55 6500 running. But one issue has me scratching my head, when I drained the old oil, I only got 4 qts out of the engine, even though the dipstick read full. I know the proper amount should be 5 qts.
The engine has a '59 block, and the prefix code on the block ends with "L" (6000 series truck engine).
Could it have been re-assembled with different parts? I did some browsing through the forums here and decided to take some measurements:
Dipstick (take these with a grain of salt) from cap to end - 15 11/16", from cap to FULL line - 13 29/32"
Dipstick tube - 7 1/8"
Oil pan, mounting flange to plug (measured from outside) - 8" deep
Any help would be appreciated smile
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
There are so many possible combinations of oil pans, dipsticks, and dipstick tubes that it's hard to say what's right. As long as the crankshaft and connecting rods don't dip down into the oil sump and whip the oil into foam at highway speed, adding another quart above the "full" mark probably won't hurt anything if it makes you feel better. The only way to be sure of the oil quantity matching the dipstick mark would be to pull the oil pan, measure the depth of the pan and the dipstick, and see how close to the crankshaft the level would be with 4, and then 5 quarts in the pan. Then mark the dipstick accordingly.
A bypass oil filter will add one quart to the capacity, and only about half a quart will drain back into the oil pan within about an hour after the engine stops.
When was the last time the oil pan was off? You could have a quart of sludge adhering to the oil pan. I had that happen on a new-to-me 216.
The view of the oil pan from above looked like a satellite view of the Amazon river. I wish I had taken a picture.
Rustbucket Ranch
Rustbucket Ranch
Very good point Jerry, honestly it doesn't matter to me how much oil is in it, I was just worried that there wouldn't be enough. Once I pull the pan I'll take the measurements and go from there!
52Carl - Probably before I was born! Supposedly the trucks been sitting since the 80s. The old oil was a little sludgy when I got down to the last bit when draining.
I originally wanted to get the engine running, then pull it....but I'm tempted to go vice versa now.
